He also said that the cables currently in the cavity can be taken out and chased into the internal walls. I said is this permitted as they will be outside the dead zones coming down the walls. His reply was yes as long as protected by an RCD. I said we are using RCBO. He said that is even better. I said so it is ok running down the walls?. He said yes and that no trunking/conduit was required because using RCD or RCBO. If a MCB then protection would be required. Just checking that he right there too because I thought it needed protection in any event. Cheers guys.
