Hello
My neighbour has plumber in today to fix water hammer and sent me a picture showing results. Plumber fitted a water shock arrestor to main supply, but it looks as if it's just been clamped on instead of actually integrated with the pipe...
Does this look right? From installations guides I've seen it shows the pipe would need to be cut, tee connector used and soldered. It doesn't look as if the pipe has been cut at all, so how would the arrestor work in this case?
Thank you
Thank you
