Hanging plastic light fittings from chains
7 Mar 2007
Cambridge
Hi
I need a bit of help sourcing something , I have 15 lights I need to support from chains in a store room, what’s there At the moment is metal fittings with chains which are plugged in via Clix plugs Easy
I have these as site
https://www.rexel.co.uk/uki/root-ca...07?isPaginationRequest=true&scrollPosition=70
but I know over time because they are going into plastic fitting I need a small plate to into the fitting before a lock but is applied.
Any idea where u can get these from or what they are called ?
thank you for your help .
Hi
https://www.rexel.co.uk/uki/root-category/Cable-&-Cable-Management/Metallic-Conduit/Metallic-Conduit-Accessories/Galvanised-Steel-Male-Hook-20mm/p/2501109407?isPaginationRequest=true&scrollPosition=70
The very first hit on google for 'conduit 20mm large washer':
https://www.accu.co.uk/en/flat-wash...cGvfNpIwDgB5u68hfVWFF9Op4xNCwqiAaApQREALw_wcB
These are OTT and not cheap but it depends how many you need.
