No hot water from SHOWER 1st floor
27 Nov 2020
Hi everyone,
I have an issue there is no hot water running from shower on the 1st floor. Its not completely cold, just little warm, but too cold to shower. I only have issue with a shower head, there is hot running water from tap in the bath and the sink with no problem whatsoever. So basically i need to turn cold water tap in the bath, to get hot water running from the shower head. There is no water tank, just boiler. Any ideas how to fix that?
Thank you
Remove the shower head from the hose ,and see if the boiler now fires up and gives hot water. If it does the showerhead is scaled up.
If it still doesn't ,you will need to check the showers filters for cleanliness.
