Are you familiar with this range? What has Karen purchased?You have the wrong switch, at the moment you have 2 x 1 way switches and you need the same as a replacement.
What type of switch do you think the op has sparxxxx ??You have the wrong switch, at the moment you have 2 x 1 way switches and you need the same as a replacement.
If you are unfamiliar withthe product, how do you know it's unsuitable?Totally unfamiliar, but I know its not a suitable replacement
You can when the two of the wires are the same (note the jumper wire).
So in this case,
The jumper between two separate terminals is replaced by one common terminal.
It is - but what has that to do with it?Electricity is the same everywhere,
It rather depends on what the terminals do, doesn't it?and if you have a 2 gang 1 way switch with 4 terminals you cannot replace it with a thing with 3 terminals.
the closest you get with a 3 terminal switch ie 2 way, is to have one or the other lights on
There are lots of light switches like that these days - especially touch and wi-fi ones.
This is not a single 3 terminal switch.
It is 2 separate switches, both of which are one way, with a single input connection, and a single output from each switch.
The inputs to the two switches are combined - the Live goes in this single connection.
There are then two outputs - one coming from each of the two switches.
So a live goes into the combined input connector.
And two separate switched_live, come out separately from the two switches, to power two separate lights.
SFK
SFK
