Fiver says it's a Logicwhich boiler and why do you ask ?
My thoughts exactlyFiver says it's a Logic![]()
Biasi Riva Advance 32SMwhich boiler and why do you ask ?
there is no set time , but if it is dripping when the boiler is cold it could be the heat exchanger, have to say your boiler is not one of the usual suspects with that fault, are you having to top the pressure up constantly ?Biasi Riva Advance 32SM
Asking because I want to see if there is a leak in the heat exchanger.
Well let the boiler cool down and check to see if the condensate is dripping with the boiler off, as already said not a common problem with your boiler
No shouldnt be dripping after that timeAlready did that. Turned off for 4 hours and there was a drip every 30 seconds. Just wondered if I need to keep it turned off longer.
