- Joined
- 16 Dec 2018
- Messages
- 236
- Reaction score
- 2
- Country
I'm hoping to purchase a new front door for my house. I'm after a Hormann thermo46 metal-framed composite front door.
I'm ordering it online as I don't have any installers nearby. Consequently, I'll have to measure it myself which makes me a little nervous as it will be a big expense if I get it wrong. I've pulled apart the current cloaking on the front door and have measured where the current hardwood frame sits (the UPVC one bolts to it), so I'm assuming this is where I want to measure from.
I'm guessing using the current measurements of the frame will be okay but what's the recommendation for measuring a door. Would you generally measure brick to brick and then take off 10-20mm?
My other concern is that the place that I might need to drill through the frame to fix to the wall might be where the outer bricks join the inner blocks. I'm wondering if this is why a hardwood frame had been used previously?
Do the frames generally let you fix to the wall in any position or is it always dead centre?
