- Joined
- 18 Jan 2021
- Messages
- 4
- Reaction score
- 0
- Country
Hiya
First time posting so apologies if I have posted this to the wrong area...
I'm trying to find the best solution to seal up two holes around radiator pipes that are coming down from the ceiling inside a cupboard (I have a photo but no idea how to post it!)
Calor's engineers left it that way when they installed our LPG central heating system a few years ago, and as we had so much else to do with renovating the house at the time, we just left it. However, I'm now using this room as my home office, and whenever the heating is on I am noticing a foosty loft smell coming down through the holes (plus occasional plaster crumbs and tiny bits of loft insulation, which is annoying).
I've looked around for potential solutions for what I can use to seal around the pipes, but everything seems to have mixed reviews ranging from perfectly fine to catastrophic...
We've looked at pipe collars but don't think they will fit because the two pipes are quite close together and one of them is hard up against the side of one of the holes (also, I'm not sure if they would stay in place hanging upside down from the ceiling?)
A few people have mentioned expanding foam, but the gaps are not that big, and I have a feeling that trying to do that upside down inside a tiny cupboard would probably end in disaster.
I've read that silicone and caulk are not good to use due to corrosion problems.
The other thing I have seen mentioned is flue jointing compound, but not sure if this is safe to use in a room where I will be sitting 8+ hours a day?
Does anyone have any thoughts on what would be the safest and easiest thing to use (I'm guessing it's probably one or the other though!) Any advice would be much appreciated, thanks!
