Hello,
My house was provided with a regular single gang socket directly attached below the CU presumably as the 'EV charging point' listed in the sales info and planning permission etc. CU is located in the garage, next to where you would store a car and you could feasibly reach outside to the drive also from that socket.
It's connected with a length of about 60mm 6mm T+E to a 32A MCB labeled "car charger" which is on a grouped RCD with the rest of downstairs.
My question does this regular socket require a different earthing or RCD arrangement if it's going to be used to charge a EV?
