Tips for gluing pipe
23 Jan 2021
I have to put a 90 degree bend in a white waste pipe.
I have a miter box and saw to cut it but what glue should I use to join them and how can I hold them in position while the glue dries?
You cannot glue two bare ends of a waste pipe together.
The bond area is too small and it will fail.
You need a coupler section to join lengths of waste pipe.
As an example this is the 90deg coupler for 40mm waste pipe (you did not say what size your pipe is):
https://www.screwfix.com/p/floplast-bends-90-white-40mm-5-pack/90596
and all the other bits here for solvent weld waste pipe:
https://www.screwfix.com/c/heating-plumbing/solvent-weld-waste/cat831602
And here is the glue you use to attach these connectors onto for solvent weld waste pipe.
https://www.screwfix.com/p/floplast-sc250-solvent-cement-250ml/14295
SFK
This is the 90deg coupler for 40mm waste pipe:
SFK
What is the waste pipe on? Bath,basin etc? Make sure you get the right size
Not completely foolish, I recall a house once where the occupier had painstakingly made a Y piece to connect the washing machine and dishwasher into the same waste. Goodness knows how long it had taken him as he'd shaped both ends to a perfect fit before using copious amounts of Araldite or similar to glue the parts together.
He was also a Professor I believe, although certainly not in Plumbing.
