- Joined
- 17 May 2012
- Messages
- 11,413
- Reaction score
- 1,017
- Country
This weekend I finally had the courage to look inside this chimney. Cleared out about a foot of black dust and rubble. Cannot decide what to do with it though, remove (and put a tall cabinet there) or just box in and forget about it.
This is what I don't understand though - the bottom of the chimney is covered with a bit of wood - but it was full of dust, almost up to the bottom of that hole - so presumably the dust accumulated after the chimney was sealed up. It was dry in there, and only sign of life was one small old feather. Could all the dust and rubble be from falling offer the internal wall of the chimney? I assume this has all been sealed up for a long time, I think it must have been the original boiler (oil based in old days?). There was an old door on it that was completely rusted, as well as a newer door in good condition. Maybe all the dust and rubble came down when the builders were knocking through the 9 inch wall.... I really don't understand how all that dust would have got in there after that wooden board was fixed to the bottom ...
anyway, the chimney is half in the wall (goes in about 14cm, was once an external wall I think) and it looks like the lower part might have been removed already, going by the broken bricks on the wall on the left. It veers off to the left in the loft.
Can I remove these bricks up to ceiling level? Will that be OK? I do I need to get a builder in to remove and brace the bottom of the chimney.
It looks OK on the roof as far as I can see, and as said, very dry inside, and not sign of a draft either, so it must be sealed up.
Photos!
Photos!
