The plate heat exchanger doesnt use washersYes, A selection pack of washers, 1/2 and 3/4 should suffice.
Is it advisable to fit new washers when refitting if so are they a standard size- it would be better to get them prior to removal?
no switch the tap to Hot and just leave it open, you will get a short spurt of water then it should completely stop, take note if you are still getting water out with the boiler inlet isolated, do not proceed, that means you have a fauly mixer which would give you the same symptoms as a blocked plate heat exchangerMany thanks guys, I am able to buy a pack of 10 from wolseley for the sum of £13 ! but can get them today.
One final question.
I know i have to isolate the mains feed to the boiler ( at the boiler) and switch the lowest hot tap on. with the exception of the bathroom sink all taps are mixer, so switch them to full hot should i expect them to run dry or will there be an element of cold running through? Just preparing myself as to what to expect.
Thanks in advance
Yes that is correctthe valve I need to switch off is the one to the right of the Gas pipe?
No you need to competely drain the boiler, the plate has both primary and secondary water in it that is how it worksAlso I am presuming I dont actually have to drain the boiler as such just the hot tap?
Drain offs just to the right of ch isolation valves
there is a drain off on each of the CH pipes you need to open both, dont touch the isolation valves or they will leakDo you mean the little pipe coming out of the bottom of the far right pipe that looks like its operated by a square type screw ?(the photo isnt brilliant) if so do I also need to isolate the ch valve to be safe?
Do I presume that on the picture this is pipe 1 and pipe 5 with the ridged pipe outlet?there is a drain off on each of the CH pipes you need to open both, dont touch the isolation valves or they will leak
yesDo I presume that on the picture this is pipe 1 and pipe 5 with the ridged pipe outlet?
