Firstly, I'm loving this forum and very glad I found it.
Secondly, after using the search function and reading as many similar posts as possible, I'm still worrying about a problem we've got in our garden.
We've been planning on putting a hot tub in our garden and we're in the process of enlarging the patio area to do it. When digging out the extra area and digging down a little, the clay soil underneath is wet. I mean water comes out the ground and fills the hole that's maybe a foot below the level of the current patio, at most.
This is the area we're planning on having a 2.5m reinforced concrete base put on. The base will be 150mm thick, or thicker if needs be. I should point out that the patio around the new area we've dug out has been there for years and is perfectly level.
The builders who dug the new area out haven't yet returned to lay the base. My worry is whether it's actually suitable to lay a base for something that heavy, on what is clearly wet clay. If I pump the pool of water out, it will just refill.
I should add that there's a lot of clay around our area and we live almost at the bottom of a hill. We're used to the clay soil being wet (as it usually is) but I wasn't expecting there to be a constant pool of water when we dug down, prior to laying the base. I've had the drains checked and there are no leaks. Soak-away works OK. Yet water fills a hole even after no rain. I have previously put a 50ft fence in along that side of the garden and when digging the holes out for the concrete posts, they would fill with water even in late Spring, but those holes are reasonably deep. This fills with water and it's less than a foot down.
Is what we're doing a very bad idea and if so is there anything that can be done? To be perfectly honest, I'm not getting good vibes off the builders about it which is why I'm worried. They may be able to lay a base on it but by the time it comes to put a hot tub on and fill it with water, that will weigh about 2,000 kgs. Will the base work OK on soil like that? The builders will be long gone by then and the tub will be a huge job to move.
Many thanks in advance for your help. I'm beginning to wish we hadn't started with this so I hope you can set me mind at ease. I fear it could be a very costly mistake.
