No. Entirely unsuitable.
Armoured cable would be the usual choice.
Thanks, that's really useful![]()
As per the poster above, use Wiska boxes with the optional earthing kit, and the correct size of CW type SWA gland and you will have a robust solution. Remember that the armour should be connected to earth at least at one end.
Use the correct type of gland for whatever new cable is being run in to feed the new stuff.
Is the existing cable 2 cores or 3 cores?
Check the SWA connection at the house end to make sure its still intact and done correctly.
Some boxes e.g. Wiska have gland plates which make it easier.
Er, not for a joint which will be buried. A made for the job resin filled armoured cable joint will be the proper thing to use.
Er, where has the OP said the joint is to be buried? The cable is currently sticking out of the ground.
