I think the fitting is plastic, thats whyIt isn't correctly wired as there is no earth connection.
Yes you are right, I finally managed to get a copy of the instructions. They can be wired either way.I really don't know about this.
So why is there an "earth"wire from the centre terminal to the (presumably) metal body of the fitting?I think the fitting is plastic, thats why
OK so which is it?
Is it earthed or not?
Clearly it is so why were you saying it was not?
Certainly looks like the metal backplate you normally find to put inside a plastic enclosure to me.
Don't start on about the colour of the earth wire as this is clearly Chinese and not really meant for our market so does not follow our standards.
The two photos are different (look at the LEDs) but similar.
kate_B said:i've seen a photo of another unit ( not mine) .. In this picture live is grey, neutral is white
Neither can legally be sold in the UK without the correct wiring colours.
Your right this time Winston1 as usual.
The two photos are different (look at the LEDs) but similar. They both have a wire connection to the centre terminal to a screw on the base with an earth symbol. They clearly require earthing.
I just know that anything sold in the UK has to have the harmonised wiring colours in the mains lead
