need a MCLAREN 24V GAS VALVES
4 Apr 2021
Hi I am looking for a gas valve from a Glow Worm 45/60Boiler or an ITT Mclaren 24 volt gas valve that would fit 3/4 inch pipe
New boiler time. That valve is not available
I have one from a New World CH501boiler, about 50 years old. It's a multifunction valve, with thermocouple connection. Definitely 24 volt. Can you post a pic of yours to check it's the same? If it is you can have it for £10.
Suppose that could work.
Had the same boiler when I moved to present house, boiler got replaced with a Vaillant and then another Vaillant. GW will be kettling like there is no tomorrow. Mine was leaking as heat exchanger was cracked
He the same boiler when I moved to present house, boiler got replaced with a Vaillant and then another Vaillant. GW will be kettling like there is no tomorrow. Mine was leaking as heat exchanger was cracked
Don't know what you mean by that lot, but pics of my valve attached. Now you show me yours! :)
BTW mine has a 1/2" BSPF gas connection
Don’t’ be rude:whistle::whistle::whistle:
Sure the guy can buy your gas valve for 10 squid, not saying he should not. In fact lucky that you have the valve. What my thoughts are, how is he going to set it up. Lot else comes to mind, it is just that I do not want to rob you of the sale
In my #6 I thought I was replying to the OP, my mistake. But I didn't mean to be rude, I just couldn't understand your post. Or what it has to do with the gas valve.
Now you show me yours! was meant for the OP (who has gone rather quiet)
:ROFLMAO::ROFLMAO::ROFLMAO:
