Paving without a wacker
r_c
19 Jun 2016
My first attempt at block paving, a small 3-ish square metre section where the bins go. Lets see how this turns out. I've already spotted many mistakes, but it has been a great learning experience. :D
I am at the point of brushing in the kiln dried sand between the blocks. On the block paving videos I have watched I see that a wacker plate is used to help ensure a good distribution of the sand. I don't have a wacker plate.
I've got one of these hand held compactor things, but it doesn't seem right to use for this step:
https://www.amazon.co.uk/Roughneck-ROU64379-Rammer-Tamper-8-inch/dp/B003CT4DD6
Is there something else I could use to achieve the aim of using a wacker?
TBH a whacker plate is a key part of block paving as it beds the blocks down into the sand - usually the blocks are set higher to allow for it.
You can hire them
  • Thanks
Reactions: r_c
I have something a bit like that, but it is just a heavy chunk of iron on the end of a bit of scaf, its good for compacting small areas. When i have done block paving and knocking down after sanding; I lay a small plank of wood on the blocks (may be 24" x 5" x 2" thick) then whack that - gets a good even finish
  • Thanks
Reactions: r_c
Thank you @Munroist - that seemed to work OK ... fingers crossed!
And thanks @Notch7 . I hadn't thought to set the blocks slightly higher to allow for it. Next time I will make sure to hire a whacker plate (and a block splitter!) (y)
When I do drain repairs I never use a wacker.
I use a hand rammer to compact the stone then rubber mallet to smack the blocks down onto grit sand (Or grano).
Then once I brush the kiln dried over I tap the blocks with the mallet again to get them perfect.
  • Thanks
Reactions: r_c
