Removing plastic film from sealed window units
24 Mar 2012
Lancashire
Hi. I don't think there is much chance of a miracle solution, but here is the problem I am trying to tackle.
Years ago, someone threw a half-brick through one of the panes of our front (uPVC-framed) window. As well as smashing the window unit, it caused damage to furniture also. (I didn't ever find our who did it; we had no enemies and had had no conflict with anyone, so I think it must have just been done out of idiocy.) Because I feared that this could happen again, I stuck some transparent plastic film over all of the sealed units (it's what this film is for — protection from glass shards, if a window is broken).
Recently, one of the units has started to look as if it has failed, since it looks misted up. However, on inspection, it turns out that the cause of the misted look is the layer of film, which has "gone off" in some way. The manufacturer's instructions to remove it were to peel it off, then to clean the glass with white spirit. When I tried picking at a corner of one of these sheets, it just broke off in tiny, tiny pieces. Evidently, it has lost its flexibility. I would be afraid to use a steel scraper, no matter how thin and flexible (I have tried, starting in a corner), because it does not get under the film — the film just breaks off, as described.
Is there any wizard out there that could suggest how to remove these sheets of film, without risking damage to the glass?
Muchas gracias, if there is!
L.L.
If the heat doesn't work it's down to a steel 'razor scraper', either the small stanley blade type or the 4 inch ones. Either method will still likely leave a residue and 'wonder wipes', which can now be bought as a sprayable quid rather than hand wipes is usually good for this.
Also, change your name.
Hot air gun, razor blade window scraper, white spirit.
Or replace the double glazing with toughened units....if you know how to remove the glass, this would be quicker
Try heating it up with a hairdryer. Then use a rigid plastic scraper.
Aha, securespark, that may do the trick! It did occur to me to try softening the sheets, but I didn't think of a method. However, for me (at 87), this will be a big job (climbing and reaching, as my balance is not good), so it will have to wait until I am able to tackle it. So don't expect any report of how it worked (or did not) for a while. Thanks!
L.L.
The expense of that is what I am trying to avoid, though I may be driven to do it, in the end.
L.L.
Hmm, I should be very dubious about using a steel scraper. Thanks for the tip about Wonder Wipes, though.
L.L.
My balance is rubbish and as a consequence I can no longer use ladders.
I would recommend employing a family member or friend or neighbour with good balance to do this job for you.
Do you have anyone you can call on?
Well there are one or two relatives, but you know, after a lifetime of doing it all myself, I couldn't bring myself to impose such a task on either. It would not be fair to do that. No, I shall wait until my inner genie says, "Do it today", and follow the prompt. It usually works.
Regards,
L.L.
Regards,
L.L.
I wonder if having something like this would help in terms of not needing to worry as much about balance? Granted it's slightly bulky but if you have room for it, at least you'd be standing on a platform instead of a ladder rung. And might come in handy for other diy jobs?
Scaffold Platform | VonHaus
Do you remember how the film was added?
Our windows at work were retrospectively made safer with film. The guys used plant sprayers and water/washing up liquid. I did similar using mirror tint on some windows.
I was wondering if some heavy duty tape and polythene sheet plus a wall paper stripper could introduce steam into the area and rehydrate the film? Maybe just to loosen the grip?
There are ceramic scrapers for cleaning induction Hobbs that shouldn't damage glass
