- Joined
- 5 Nov 2010
- Messages
- 407
- Reaction score
- 3
- Country
I'm trying to put several zebra (night & day) roller blinds up.
They're quite heavy compared to your usual ones.
They don't have side brackets but clips that are fixed to the roof of the window recesses.
The problem is with this new build house is that there seems to be lintels directly behind the plaster, therefore, I can only drill about 20mm before hitting them which is not enough length to secure the clips, which I found out!
What am I supposed to do in this situation? Maybe 20mm is long enough but I had to improvise (shorter screws & plugs) as the screws and plugs that came with the blinds were too long.
Can I drill into the lintel and if so how thick are they usually?
I'm guessing that I need a drill bit that is only about 1/2mm less than the screw.
Thanks very much and hope you can help.
