As I said, 0.4 bar (~6 psi) above atmospheric pressure is a fair bit. If I recall, pressure cookers generally run at a bit under 1 bar above atmos, and they most certainly "WHOOSH" (this time in uppercaseWon't it be more than merely the 6psi pressure being 'allowed out' as the water will then boil and steam be formed? ... Look at taking off a car radiator cap when the engine is hot, albeit that is (usually) 13psi.
