Can you get 4 x 2 in lengths of 6+ metres?
I need 2 lengths a fraction over 6 metres and approximately 15 lengths 3 metres long.
It's for a shed base raised on small stilts because of a sloping ground level. The small stilts are 3" x 3" sunk into the ground approximately 12" deep on a bed of gravel and postcreted in place. The lowest section above ground will be 2"-3" and the tallest about 6" above ground.
Frame size is 6m x 3m of pressure treated 4" x 2" on edge then cross beams @400mm centres with staggered noggins to maintain rigidity.
