Hello all,
hoping some clever people will be able to help my nephew in his new home?
Fault:
Main System 24HE Boiler (not combi) Tank in loft & HW tank in bedroom
Boiler pressure is too high, at rest & not in use it is sitting at 2.5 bar & the external wall overflow pipe is constantly running (recommended 0.5 - 2.5 bar range on boiler)
We have released the pressure from the system (release valve) to 0 bar, then in a relatively short period of time the pressure returns to 2.5 bar & the external overflow is running water again (boiler is not calling for any heat at this time)
If we turn boiler on for Hot Water (for example) the pressure will raise up to 3 bar & it would seem that the external overflow pipe Stops from running water! (we do get the hot water)
If anyone has any informed ideas of what is causing this issue they would be much appreciated & thank you for any help.
(sorry pics are a little blurred but away from the property now)
Fault:
