baxi combi 100HE plus loosing pressure
there is a little plastic cap on it (like a cap on a car tyres air fill valve)
turn it anti clockwise a couple of turns to open
ok seen a couple of these one on the red vessel another on a valve on top of system gold looking valve
Being the owner of one these and on my 5 PRV I would moncur it's your PRV.
I do wonder what caused it to blow the first time though. I'd have the guy check your expansion vessel when he comes to fit the new PRV.
if its a push fit
isolate boiler electrically
isolate flow and return
open prv to drain
remove and replace with new
open flow and return valves and re pressurise to 1.2 bar
vent pump
make sure AAV is open
you never drain thro the prv it will start leaking :shock:
Could some one please confirm this! I had a central heating engineer come and fit a new radiator to my system last week and he dropped the pressure off via the PRV and ever since then the pressure appears to keep dropping and water is collecting in the bucket I placed below the valve drain outside - could he have caused this problem?! If so I'll ask him to come back and sort it out! Many thanks
