So a strange request I have had to help someone out.
Basically they want to be able to switch all the lights on in a building at once, regardless of the position of the wall switches. They want to also turn them all off (or at least return to the previous state when they turn the central control off.
To me it seems the only way to do this would be parallel switching, basically take 2 lives from the same MCB, run one live through the wall switch to the light fitting and take the other live feed it via relay to the light fitting. So you would have 2 live wires at the fitting.
I have tried to find reference to parallel switching in the regs and can't! Part of me says you can't do it, but part of me is struggling to find a reason not to if you put a 3 pole isolator beside each light fitting to isolate it for servicing purposes. My background is electronic engineering and in the past I did used to specify some electrical systems within my job, but it's long before the latest regs.
It's essentially going to be like the systems you see if movies for switching all the lights on in a fire station, when the callout alarm sounds.
Any thoughts? Or at least where in the regs it states you cannot parallel switch the live?
