Door threshold
11 Mar 2014
Yorkshire
What’s the accepted way of building the door threshold in a cavity wall.
The floor is a concrete slab insulated and screeded upto finished floor level and I was wondering the best way to run the floor upto the outer leaf at the door opening.
Seen various ways when I google it but would appreciate any pointers.
When building an extension the best way is to stop the inner course at same level as concrete oversite.
Then run insulation across to back of outer skin, then screed over.
DPM is needed where screed butts to outer skin.
I'm not sure what stage you are at, if you have inner blockwork coming up to top of screed you have a thermal bridge and a day joint effectively in the screed floor.
Thank you, that’s the sort of way I was thinking with the screed coming all the way over to the outer leaf,
You can either fill in the cavity by putting in DPM then concrete.
Or leave cavity - (which I prefer), run insulation across and screed over.
If it's insulation of say 100mm thick, it won't need supporting over a 100mm cavity once screed is down
Nice one, think I’ll run the insulation across cavity and screed like you suggest.
Thanks again buddy
