- Joined
- 11 Jan 2009
- Messages
- 1,049
- Reaction score
- 5
- Country
Hi
I’d previously drilled a hole through an internal, load bearing wall (from lounge to conservatory) to connect aerial cable to tv. Cut long story short, had to widen hole a tad to allow new coax cable. Thought it would be easy with existing hole. However, the hole is only a few inches from the ground and a long drill bit needed as wall about a foot wide. I drilled, then realised to my horror, the bit had slipped in the wall and gone off on a tangent. The new hole is lower and to the right of original, and I thankfully stopped before it went through skirting board!
What I also only discovered today was that the original smaller hole was drilled at an angle, with exit hole in conservatory higher than hole on other side. Think this was due to drilling at low level with a long bit. I’m assuming it’s a damage limitation job now, but would people advise drilling down rather than up with the bigger but?
