I'm trying to work out what the most economical heating system set up is.. i.e. which is the cheapest to run (i.e. which uses the least amount of gas / electricity). For the purposes of this question please assume that all three setups are perfectly adequate for the users needs - I'm just interested in running costs. Also please ignore installation/materials costs. All three will supply just Central heating and hot water just a very simple system (don't worry about zones, multiple showers or underfloor heating, etc)
So the four options are
By the way not sure about the fourth option.. can you have a heat only with unvented cylinder or does it have to be a system boiler?
- Vented cylinder with heat only boiler
- Unvented cylinder with System boiler
- Combi boiler
- Heat only boiler with unvented cylinder
