Replace MCB with RCBO's
Maybe I’ve got that wrong, but I’m sure I read on here somewhere that there needed to be a means of providing local isolation (e.g. via an FCU) to a thermostat that could otherwise only be isolated at the consumer unit. Thinking about it, the thread I’m thinking of probably relates to underfloor heating so I assumed it would relate to wall mounted electric rads too. As it stands, the circuit runs consumer unit -> thermostat -> FCU -> Electric heater.
I’ll see if I can track down the thread I’m thinking of.
tbh makes my life much easier if I can leave things as they are.
As you probably realise from my question, I'm unaware of any such regulation. In fact, as far as I am aware, there are extremely few (if any) requirements in the Wiring Regulations for anything to have a 'local' means of isolation in domestic premises.
Having said that, it often makes sense to have such means of isolation, in order to avoid having to disable too many things (at the CU) when something 'goes wrong' or needs attention. However, that's different from a 'regulatory requirement'.
If there’s no requirement then I don’t see the need to do it and I’m all the happier for it. One less thing to do.
My installation has three independent heating circuits covering the bedrooms, the hall & kitchen, and the lounge which in my mind offers enough discrimination and local(ish) isolation given the CU is just outside my front door in an adjacent utility cupboard.
If there’s no requirement then I don’t see the need to do it and I’m all the happier for it. One less thing to do. ... My installation has three independent heating circuits covering the bedrooms, the hall & kitchen, and the lounge which in my mind offers enough discrimination and local(ish) isolation given the CU is just outside my front door in an adjacent utility cupboard.
Fair enough - as you say, that doesn't sound unreasonable ('convenience'-wise).
As for whether there is a 'requirement', you'd better wait to make sure that no-one comes up with one - but I doubt that they will!
indeed. If someone knows of it I’m sure they’ll be forthcoming.
Well, it took me most of an afternoon and into the early evening, but i got it done. Surprisingly hardwork getting it all to fit. Not helped by the CU being quite shallow in depth, and there not being a lot of space behind the RCBO's once fitted - hence having to run the functional earths over the top. Not ideal, but it works. I know theres some debate about using bootlate crimps, but i love them - makes terminating multi core wires so much easier. Aesthetically, i like the yellow on blue too.
Whilst i was doing it i thought i might as well put in another couple of 32A's whilst i can get hold of them - gives me the option of running in a second cooker line and a kitchen ring when i replace the kitchen. Taking out the double width RCD means i could always potentially add more later too - though tbh its getting so busy in there that at that point i think it will be new CU time
Have you noticed the CU getting warmer? I was looking into RCBOs but one of the concerns I noted was that the parasitic current draw is much higher - up to 5W per RCBO.
when i took the cover off yesterday to do some more testing / tidying up i did notice some of the 32A RCBO's felt warm. Don't really have any sense of what the MCB's were like so i can't say if this is warmer or not. When i get a moment I'll take the lid off again and grab a thermal image - got one of those thermal camera add ons for my phone a while back. Can't say that my electrical monitoring system has picked up an increase in the base load of my flat - certainly nothing in the region of 50W (5W per RCBO). If anything, my base load seems to have dropped - but that's probably because i didn't plug something back in...
