Saniflo
5 Nov 2009
Liverpool
Hi
can someone send a link again for a compatible saniflo again.
The unit in the picture is the Saniflo for a WC only, if you are looking to replace it then the direct replacement would be the Saniflo UP (product code is 6001).
I hope this helps with your enquiry.
The same as in the link I provided then.
@Joe 2017, the new one will be a touch wider so hope you have the room to squeeze it behind the pan and you`ve done well to get 18yrs use out of yours!
Ours is still going strong after more than twenty years old, but I hope it keeps going as parts no longer seem to be available for it.
Good to hear it and people slag them off for not lasting! I still have some parts for the pre 2005 models.
Thanks Hopefully I won't need to, but I may contact you in the future then, I needed a tank lid seal for a Sanitop that has a flat front rather than a swept back one but had to make my own work around as Saniflo could only provide one for the latter model.
Yeah the shape of the tank & lid changed around 2005. My stock is all components no tanks/lids.
