Audi A5 Coupe 2015 2.0 Diesel
8 Nov 2006
London
Dear All
I have an Audi A5 2015 2.0 Diesel. It has gone into limp mode and Ross Tech Vag Comm gives the following error:-
019225 Boost Pressure Regulation.
The Car been to a Garage as it bought from a Dealer. The Garage say they replaced Turbo and cleaned DPF.
Upon driving it the same problem has appeared! Please see attached diagnostic photos. Anybody have any idea what the real issue maybe?
Many Thanks All.
Caesar ( Should have stuck to the Chariot, little fuel costs and No congestion charge!!)
As you have VCDS can you run a live log (While a 2nd person drives the car) choose "boost requested" and "boost actual" among the criteria to log. If the turbo has been replaced but is failing to boost this will show how much by. It is possible that the garage may not have changed the turbo actuator and it is also possible that they may not have cleaned debris from the intercooler if it was a physical turbo failure.
Other areas to check are boost hoses collapsing (delaminated inside), boost leaks and also make sure the EGR valve and the anti-shudder valve are not clogged with soot and operating correctly.
Was the replacement turbo a new one, or just a replacement?
I’d go for the large diameter air pipes from the intercooler to the turbo being adrift.....you can feel the boost pressure when you squeeze them.
Also look for the small air pipe going to the turbo actuator coming adrift or split.
John :)
Hi All
Many thanks for the solutions, will take a look and let you know the outcome.
Regards
Caesar
Hi All
Things get even stranger! Now have the following codes appears!!
P029900 Turbo / Super Charger Underboost
P208E00 Reductant Injection Valve stuck Close Bank 1 Unit 1
What are these codes now indicating?
I think the adblue valve is stuck. The car doesn't need to go into limp mode for it's own health but EU regs stipulate that it must. Adblue equipment is subject to failure from crystallizing especially if a car is laid up for a while. It is quite common for people to get an ecu specialist to "delete" the adblue part of the software from the cars ecu.
I would try filling the adblue first though, 615 miles range means there really may only be a splash in it!
sounds like the dpf is getting blocked quickly as its not regenerating effectively.
it's surprisingly common and causes all sorts of issues.
a lot of the time just cleaning the dpf fails to fix the problem and a new dpf is required.
in your case the injection valve appears to have failed, again quite common.
on the pool car at work we ended up having it all deleted and the ecu remapped to stop it occuring, we repalced everything and spent thousands on it, with no real fix.
since deletion its been tickety boo.
Hi Folks
Just a quick update the AdBlue injector was replaced and AdBlue topped up to full BUT the dash Light still stays on!!! Car still says that it only has 250 Miles before Adblue runs out! Heard car will not restart once Adblue runs out??
Audi Specialist who did the work says that the light can only be reset by Audi! Does anyone know how to reset this light without having to go to Audi???
The only error code coming up on VCDS is 00003 control module. No other error codes have come up, the audi specialist has shown the rest of the codes showing the car itself has registered the work and the full amble but states the 00003 control module code for basic setup is just for the adblue warning light.
any help will be greatly appreciated.
Many Thanks
Caesar
Hi Folks
Many Thanks
Caesar
A lot of more recent cars can actually detect their own Adblue level and as such "reset" themselves, however, the earlier Adblue cars had no facility to check their own levels and did indeed require a reset via OBD. It is quite possible/probable that your car will require a reset before it "knows" it has Adblue in the tank.
Hi All
Many thanks for the reply. Tried resetting with VCDS no joy! It reports a fault with the control module and looks like the instrument cluster will indeed need to be reprogrammed by Audi! Not sure what the cost of this will be, been advised it may take hours to do and Audi will apply their hourly rate!!
