Hi
I have a wunda underfloor heating wiring centre that calls for heat and fires the boiler from a switched live that connects to a zone valve.
When the call for heat is made the RCCB trips. I have disconnected the pump and tested and it's still tripping so maybe it's a faulty zone valve or faulty wiring.
It worked perfectly but it has not been run for some time and in that time the power for the wiring centre was moved to a new fused spur on my new extension with a new fuse board with the RCCB. Previously the wiring centre was on the same circuit as the boiler and zone valve ( main fuse board RCD protected). I don't know if it's a coincidence or not.
I put a mutlimeter on the wires that call for heat from the zone valve and as soon as 240v hits the zone valve it trips.
Can someone point me in the right direction for some other testing I can do.
Robbie
Robbie
