Hi
Ridge and verge on our 75 year old need re-doing. Definitely decided against any dry verge many roofers seem to think is preferable.
However, not so sure for the ridge, the dry system would provide ventilation whereas the wet does not, however the current ridge tiles look good as new and plastic ones certainly won't last decades like these are.... can anyone advise on pros and cons of the wet or dry ridge? And what, if anything, can or should be done for ventilation at top of roof in the wet system?
Also, what is a good mix to use - esp for the verges. I've seen houses in locality that have been redone and its an awful grey mess that's often cracking. The current pointing in the verge of our house is more beige, and you can see sand (almost fine gravel) and what looks like bits of chalk?? It's lasted ages and looks so much better - any ideas on what this might be/best mix for longevity?
Thanks in advance.
Thanks in advance.
