Long story short: I instructed a company to put in new windows and doors. They did most of it but it was quite sloppy and in a few areas they haven't finished. I'm unable to get them to come back to finish it off so I'm looking at finishing it off in DIY fashion.
There's two windows where there is a large-ish gap between the frame and the wall on the inside in which it sits. I can feel a draught coming from the gap. Here's an example:
Can I fill this with some expanding foam in a can? Cut it down to be level and then just attach a window sill and trim on the other sides?
The other issue is the frame around the rear door. It's a full glass door (the frame is Smart branded). Here's an example picture:
It's a bit hard to tell from the photo but the inner white tape is on the door, the door frame is then the black border outside this, but then the outer white tape is also the frame but it is set back a bit from the rest of the frame. I feel this needs to be finished as it is an ugly big gap.
What's the best way to fill this? Is it with expanding foam, silicon or something else? And then is this covered up with some trim?
Grateful for any thoughts or suggestions
