So I need to fix mdf skirting to dot & dabbed plastered walls.
The walls should be straight but I cannot say the floors are exactly level.
Do I place the skirting right to the floor or hover it about 2mm above to remove any undulations?
To fix the skirting I am in two minds - either use foam or a polymer adhesive like Fix All or Everbuild Multistick adhesives.
As to foam should I use an expanding foam or some other specialised foam?
For about 100m of skirting - how much adhesive should I get? Box of 12?
Would adhesive / foam be enough or should I also use lost head nails? On 18mm MDF can I use 25mm nails or should I go longer?
