Why not?Nonsense.
"Would of" is used daily.
Just because we know what is meant is no reason to continue using it.
It now appears in dictionaries.
Why not?Nonsense.
OK - but it was surely those separately-supplied covers (not the combination of them and the 'plug' itself) which might, back then, have reasonable been called a 'plug top' wasn't it?For what is worth ( and I cannot find images to prove it ) there was decades ago a type of plug that had semi-protected terminals for wires and supplied separately were covers which provided full protection from inquisitive or wandering fingers. Not intended for domestic use.
We've tried that on a number of occasions in the past, and have essentially got nowhere.
Why not?
As we have often discussed, I personally don't think this is quite the same as many other issues of 'evolution of language' which we discuss. Rather, it seems to be a case of 'propagated sloppiness', aided (as you say) by grammatical/linguistic ignorance. I don't regard it as all that different from "dropping H's " [I know that apostrophe is grammatically incorrect, but I can't think of a better way of writing it! ]Referring to "would of":
I always do write 'should have'.In fact (increasingly true the more 'formal' the writing becomes) many would not even write " should've " - but, instead, would write the full version of "should have ".
So do I (other than in very 'informal' writing) - and, as I said, I would imagine that the same is true for the vast majority of people. Indeed, it's only in fairly 'informal' writing that I would use any such abbreviations - hence (in more 'formal' writing) I probably wouldn't write the " it's " I've just typed (I regard forum posts as 'informal' writingI always do write 'should have'.
You may not 'accept' it, but you'll (i.e. "you will" !) very often see it written - and, indeed, I write such things myself (in 'informal' writing), and certainly use them widely in my spoken English - and the same with "would've", "could've", "might've" etc. One problem is that, as far as I am aware, none of these sorts of abbreviation are really 'officially recognised' (although dictionaries may 'document' them), so there are probably no 'rules'.I do not accept 'should've' is an appropriate abbreviation as should be pronounced 'should ve' and people still pronounce the 'a'; with some actually pronouncing it as an 'o' leading to the stupid error.
Interesting suggestions, but since I have never seen either of those done, I think you're onto a loser there!If it must be written as an abbreviation then it should be written as "should'ave" with or without the 'e' ...
As I said, I'm aware of no 'rules', but if an apostrophe is used to indicate the omission of, say, "o", "i", "a" or "wi", I don't see why it can't be used to indicate omission of "ha".... merely dropping the 'h' as people frequently do - but no other words are written with an apostrophe instead of the dropped 'h'.
That's my point. The 'a' of the 'ha' is not omitted.As I said, I'm aware of no 'rules', but if an apostrophe is used to indicate the omission of, say, "o", "i", "a" or "wi", I don't see why it can't be used to indicate omission of "ha".
