Hi all,
we are currently renovating an Edwardian flat with suspended timber floors. The living room and part of the hallway have a suspended timber floor. The doorstep between the two rooms was covered with brittle cement/mortar (and carpets on top).
I have removed the brittle cement and replaced floorboards in the living room. But I am wondering what I should cover the doorstep with.
- cement as before? Don't think that'll look good with exposed floorboards plus probably will become brittle quickly again (as it is a thin layer only with some overhangs over the bricks)
- a floorboard? Guess in this case I would have to put some sort of rubber underlay onto the bricks and than fix the floorboards with anchor/screws
Would the floorboard work? Would I need to leave some gaps to let the wood expand?
Other small problem is that there is a 2-3 mm height difference between the floorboards in living room and hallway.
Below is an image showing the situation, one with another loose piece of cement next to the tiles lifted.
