Simple question this time, but can anyone give me a step by step of how to time the immersion switch in the photo below to heat a house at a certain time every day?
That does not seem to make sense, the standard immersion heater heats domestic hot water (DHW) not the house. This diagramtime the immersion switch in the photo below to heat a house
shows how many heat sources can be used both to heat domestic hot water (DHW) and central heating (CH) so there are cases when the immersion heater can heat the house. But I fail to see why a timer is used an a standard immersion heater, they heat and cool so slowly seems pointless.
I would call that insignificant.quite substantial
My boiler runs for approx 20 minutes even when programmer allows 1/2 hour, it is 18 kW and clearly also heating pipes, so 24 kWh per week, so at 15p per kWh using electric looking at £3.60 per week to maintain DHW at a reasonable temperature.
You checked energy prices recently?
Even if you double it, not really quite substantial.
Start by pulling all of the plastic 'fingers' around the circumference out with a finger nail, they will click. Then just push the ones in for the times you want it to be on for. There are four fingers per hour, one per 15 minutes - note you may need to rotate the dial, to adjust some of the fingers and it can only be rotated clockwise. Then set the time to the correct time, against the pointer on the left.
Below the dial is a slide switch, which allow you to override the times of switching, it will have three positions - on all the time, off all the time and normal operation based on the time clock.
