Paralell lighting circuit for leds
10 Dec 2009
Middlesex
Ive got 5 low voltage leds (12v) that need to be wired in parallel.
Was going to connect each light up to a terminal block with a pair of 'link' wires for each unit to complete the circuit
Similar to this example
Instead of doing this could i just use a junction box to connect all the live wires up to a single terminal, then the same for the negative wires and then connect the positive and negative wires from the driver to the corresponding terminals in the JB?
If that would work it will be a bit tider and less wires to cut. Any advice welcome
In the main we try to limit it to three wires per terminal as over that likely one wire may not be fully clamped. But I would think likely you would get away with four, give wires a good tug to be sure. Personally I would use a lighting junction box like this
for neatness.
The answer to that question is yes.
