Hi, just signed up and wondering if anyone here can help with this one…
We live in a 1920s solid-walled house (red brick, cement rendered) that has a tendency towards dampness in the basement. Generally it’s all in check but we do get the odd issue here or there.
When we moved in we had gas heating installed and the meter box is located externally on a bay wall, unfortunately we had to have one of the airbricks removed and the hole filled as they won’t mount the meter otherwise.
Gradually we’ve noticed damp starting internally on this wall that we are pretty sure wasn’t there before. I was suspicious it’s something to do with filling the vent as something could be bridging the DPC. I had a hunt around in the basement and noticed that the hole hasn’t been fully-filled, instead only the front portion has been filled a little and rendered over.
Outside with the damp meter and the wall is good, apart from the filled in section that’s going off the scale (30%+) So I’m thinking this is the problem, I just don’t know how to solve it. As this portion of wall is now thinner, no doubt it is colder than the other walls so will be getting condensation internally. If I fill the hole completely, I will end up bridging the DPC, so that won’t fix it either. I can’t move the meter as any other location would have the same problems on the front of this house. I can’t put in a new air brick either.
I’ve covered the outside area with some waterproof tape and DPM as a temporary ‘wonder if this will fix it’, but it’s not a permanent solution even if it does work.
Any suggestions appreciated as I’m pretty much out of ideas.
