It depends on what was agreed. If it was a top rate professional, get it redone.
If the tiles were problematic i.e. low quality bargain basement tolerance then the tiler shouldn't have agreed to laying them in brick bond. It's trivial to check this before laying, usually even if they are "bad" all the tiles are bad in the same way so it can be accounted for. Sometimes you do get random extremely poor tiles that should just be rejected by any professional and it explained to you.
"There are permissible manufacturing tolerances for ceramic tiles defined in BS EN 14411; certain types of tiles, e.g. extruded or large format, might have permissible surface flatness irregularities that cannot satisfactorily be accommodated within the surface flatness tolerance permitted to the tile installer; this should be taken into account when evaluating the achievable flatness of a wall/floor tiling installation."
