Atlantic F127 Electric Heaters not turning off
25 Nov 2019
Hi There,
Does anyone have any knowledge or experience of an Atlantic F127 electric heater?
They seem simple enough, it has 2 modes Basic and Prog and the manual says Basic means manual, so set the temp and it will kick in or out depending on the current temperature, and Prog whereby it should use the timers.
I've set the timers to relevant start and stop times, however when the time ends the heater just seems to carry on and not shut off.
Its almost as if the room is below a certain temp and therefor the heater still wants to achieve that temp even outside of the programmed hours.
Has anyone ever come across this?
Thank you.
How long have you left them to cool down? Is the time set correctly? Could be a faulty switch?
Hi Chris,
Thanks for the reply, only 5 minutes or so but you can still feel the heat blasting out, whereas if I unplug I notice a change almost straight away so it just seems to be staying on, the main time and each day day seem correct. This is brand new and just been installed.
I'll take another look if it doesnt seem like an obvious setting I've missed.
On another note, do you have an opinion on these heaters ? Basically my friend had Economy 7 in a rented house and the heaters were awful, the landlord has removed to 2 large economy 7 heaters and replaced with 2 of these Atlantic ones, one upstairs and one downstairs, they are half the size and although they do kick out heat it just doesnt seem enough to me and they have to be on full whack for hours to make it any kind of comfortable... and the electric bill is going to be through the roof.
Thank you.
Tbh I’ve never heard or have experience with them, so I wouldn’t know really. Could be faulty out of the box?
Ah ok, I'm not convinced the landlord hasnt just stuck something really inadequate in, these heaters are £85 each, surely 2 of those is not whats needed to heat a house, they are tiny and could have just gone to argos and bought 2 basic heaters.
It all depends on heat loss calculations, u-values, etc. If all that’s been worked out, then they could be adequate?
