Rubber washer seal fittings
would this be preferable?
Pipestation Bolofix 15mm X 1/2" Male Iron Flat Faced Isolating Valve for Tap Connector Flexi Pipes Pack of 2 https://www.amazon.co.uk/dp/B06WRQD...abc_4SP2FA9BWXWNEQHHF7JN?_encoding=UTF8&psc=1
Always buy reputable ISO valves if you can, never used these ones so couldn't comment on how well they would last. What you fitted is the better option, coupled with good quality ISO's. Either those or use these into the ISO valves.
th
The shower hose washers usually don't fit, I've tried them before, well when I say they don't fit, the ones for showers hoses I've tried don't but they seem to change all the time.
th
Plagarist !!!
