- Joined
- 5 Oct 2020
- Messages
- 144
- Reaction score
- 3
- Country
Hi All, I've purchased a campervan and replacing the leisure battery with 2 x AGM Leisure Batteries 150Ah each wired in parallel therefore retaining the 12V (for the habitation area I. E to run the fridge, lighting, TV etc, which are all 12v appliances).
The van also has a 230V Hookup point on the side for charging the leisure batteries via a PSU/Charger and also powering 230V sockets inside the van.
Ive got all my parts I need, however the issue I have is the cable running from the load side to the battery is less than 4mm (I measured 4mm but this is including the insulation therefore probably only 3mm conductor once stripped) but i need to cut off the existing battery terminals and replace with 8mm eyelets to fit the new battery but I can't find any 8mm suitable as the load side is fitted with a 20amp fuse near the battery and the eyelets I can source are only 19amps?
Do you think that 1amp will make much of a difference?
