The reason why we inject into deltoid muscles, is to:
a) avoid hitting veins which are large enough for the needle to penetrate
b) allow rapid dispersal of the vaccine through the blood
As said before, needles are sized to be larger than the small blood vessels in the muscles.
NHS says it is safe, nurses say it is safe, statistics on vaccinations (all, not just covid) say it is safe.
Maybe write to the health secretary with your concerns rather than swear at people on a DIY forum ...
Deltoid:
a)
Nobody is disputing the reason for injecting into deltoid muscle. It REDUCES the chance of vaccine directly entering the bloodstream directly, and has other usual benefits.
Normally it doesn't matter about entering bloodstream - that we know of. How often do we have
millions of cases to examine.
A problem has come to light, that vaccine entering bloodstream appears to cause a problem that we have been seeing. It was suggested as a possibility based on knowledge and experience, and found to be true in mice which adds weight, wouldn't you say?
(There's also the case(s) cited where someone tasted something immediately which is a sign of an injection entering the bloodstream, and he has the damage. It would be worth asking more victims.)
So the
simple choice of injection site MAY NOT avoid the problem.
I don't see what's complicated about that.
b)
I don't remember if I've read an explanation from mfrs on that. The muscle is well supplied with blood vessels but if you WANTED the jizzm to enter the bloodstream rapidly you'd go I-V.
Using the muscle is a generally, away to let it get into "the system" slowly. But not as slowly as S-C which has other problems
You seem to have missed the point that if you don't go into the bloodstream the vaccine goes into interstitial spaces and through a number of lymph nodes, which it meets a lot of the dendritic calls they bang on about.
Reference please for
"sized to be larger than the small blood vessels in the muscles."??
Nobody is suggesting that the needle has to get into the blood in a specific mechanical way. The needle obviously ruptures whatever it passes through, the liquid comes out at high pressure and is constrained to some extent by the surrounding material.. Nobody has specified how much vaccine would be a problem. The suggestion of "hitting a blood vessel" would obviously qualify and is a sort of shorthand. It's making a little straw man to suggest "you're saying exactly this will happen, and it can't possibly because" then add claims which aren't supported.
"NHS says it is safe, nurses say it is safe, statistics on vaccinations (all, not just covid) say it is safe."
No, no, no, and no.
Did they have the results of millions of test cases when they said that? NO. Would they readily admit it and change policy? Probably not, there would be resistance on the basis of cost and convenience and the political impact. Nobody claims the jabs are "safe" - not an appropriate use of the word. Statistics on vaccinations do not say it's safe, they say the benefit is worth the risk.
"Maybe write to the health secretary with your concerns rather than swear at people on a DIY forum ..."
Nadim Zahawi (sp?) said there is no evidence. Well no **** Sherlock, look for it.
This is a forum where everything is discussed in the appropriate subforum.
I don't se why the issue can't be discussed without it being one where some people think it's ok to post groundless and provocative junk. They need swearing at!
I'm not a source here other than for common knowledge stuff easily found.
All I'm saying is that there is a case to answer.
