Worcester 24i Rsf Very Low Pressure
6 Jan 2022
Hi all,
I moved into a house recently and noticed that the heaters and not working very efficiently. I noticed that the pressure gauge is below 1 and by searching online I saw i need to repressurize the system. I am looking for the little flexi pipe to allow some water in but after searching for hours I cannot find it and would be greatful for some advice where it could
Find your water inlet (mains in or to the head tank) and trace
Pressurise to 1 Bar max and then watch the gauge as the radiators heat up, turn the heating off if it creeps pass 2 bar, the chances are the expansion vessel is flat and needs sorting.
One end of it is shown below, can you check above the boiler or see anything at all from below?
