Correct way to repaint surface
17 Dec 2018
About a year ago, I painted my staircase.
Applied zinsser bin and dulux satinwood oil based trade paint
The dulux satin wood has come off in a few places and needs recoating
Can I just simply sand the area a little with some 180 grit sandpaper and retouch with the satin wood? Or do I have to do something else to ensure longevity?
Zinsser Bin is a primer. Then you would undercoat on top of that, then top coat on top of that. If you don't, it's likely to peel.
If I was painting a wall would I need to use undercoat before topcoat as well? Or could I use oil based primer, then oil paint top coat
Currently, existing wall has waterbased emulsion
You would just use emulsion.
I would advise against oil based paints on walls. It really, really stinks and you will find that the paint will become darker behind fittings and pictures. In the old days, I used to occasionally use dead flat oil based paints but these days you can get waterbased versions (admittedly they are less durable).
Opps you're usually right on the money..
But I have to disagree with you on this one..
The oil based satin finish looks so tasty.. I couldn't be more pleased with the outcome :D:D
Pic was while both the black and white paint were drying
To quickly get rid of the smell, I used an Ozone machine..
After 12 hours the smell was barely in the room.. After 36 hours the smell was non-existent
Thanks for the help and comments guys
I must admit, that I once painted my kitchen walls with oil based eggshell. I started of by lining the walls, applied two coats of acrylic primer, sanded everything flat and then followed up with 4 coats of oil based eggshell (sanding between coats). I absolutely loved the finish, it almost looked like a sprayed finish. It was so durable that you could scrub it with a green scouring pad.
Regrettably, over the years it did discolour, the walls that got direct sunlight were noticeably darker than the ones which didn't.
BTW, I am genuinely impressed with your wall. Kudos.
