- Joined
- 16 Jan 2022
- Messages
- 3
- Reaction score
- 0
- Country
I'd like to put up a monitor arm in my home office. I'm hoping to attach it to the external wall.
I drilled a small hole to test the material in the wall and was surprised that the drill went had some resistance at first, then suddenly moved freely a little way (maybe an inch) and then met resistance again. I stopped at that point unsure that I understood what material I'm drilling into and whether the wall would be able to support the monitor arm weight.
Having done some research, I think this wall is probably a 'dot and dab' construction and therefore I assume there's a plasterboard, with an air gap, and then the main masonry wall. When I tap on the wall with my knuckles it sounds hollow in the area where I drilled, and more solid lower down. The house was built around 1890.
The arm I'm fitting is this one:
https://www.amazon.co.uk/gp/product/B07QTTNTFX/
and it would be to support a 27" monitor weighing 5kg
The arm itself is supplied with two 10mm dia wall plugs and two fairly hefty bolts 8.5cm long (which would penetrate the wall around 7.5cm)
Can anyone advise me about how to best proceed with this. Would the bolts likely be strong enough anyway because they will grip into the underlying masonry because they are long (and quite strong -- 6mm diameter)? Or should I rethink?
This website seems to suggest that you need to cut through the plasterboard and fit a wooden spacer, which is perhaps more than my DIY skills are up to
https://www.diydata.com/general_building/wall_fixings/wall_fixings.php
Thanks in advance for your advice!
David
David
