Evening folks,
I have a radial circuit in the garage which is fed from a single 16A breaker through 2.5T&E. It has 6 x 2-gang sockets on it. CU is in one corner of the garage and the final socket is the opposite corner. Total run is around 30m I estimate.
The garage CU is fed from the house from a 40A MCB over 6mm armoured and into the CU which has a 63A ELCB.
I want to put some more sockets on the "blank" wall and easiest would be to have another run from the CU through to the new sockets (I will add 3 x 2 Gang) and then on to the end of the radial.
Can I simply do this and change the radial to a ring and the 16A to a 32A?
C
C
