- Joined
- 2 Feb 2022
- Messages
- 4
- Reaction score
- 4
- Country
Hi, I just put an indirect cylinder in for someone, simple one in one out..or so I thought.
When I fire up heating and hot water all is well, when hot water only is selected, the water from the boiler spills over into to f and E tank in the loft.
I've tried turning the pump down but it still happens.
It's a potterton condensing boiler and seems to be a bit patchwork system where there are two pumps, one above the boiler with a zone valve for the hot water, and the same underneath for the heating.
It doesn't seem to be the expansion of system water getting hot as if I turn the actual boiler off, but keep the controller etc.. on the pump and zone valve run/open and cold water flows over the top.
The vent is located on the flow just before it goes into the coil.
I'm stumped I must say..any ideas?
