- Joined
- 5 Feb 2022
- Messages
- 23
- Reaction score
- 1
- Country
Not entirely sure this is the right place for this but seemed the best option. I bought a house just over a year ago and frankly its turned into a bit of a disaster so far but that's another story. The main issue now is the house is absolutely freezing. I don't mean its a bit cold and you have to put a jumper on, I'm talking heating going full blast all day, multiple layers and under the duvet sat on the sofa and its still cold.
I'm not sure why and therefore I'm not sure where to start with fixing the problem, or even if its worth fixing or if I'm better off selling up in the next few years.
Its a mid-terrace built in the 1930s. I moved from a similar house in the same street I was renting and it was nowhere near as cold as this one.
The biggest problem is downstairs which is essentially one big lounge / diner and kitchen which is an extension but in the 80s. There's a radiator in a bay window at the front, and another on the wall in what would be the dining part of the room and a very small one in the kitchen extension. The two bigger radiators are hot when on but if you move from standing right in front of them you can't really feel anything. The kitchen is absolutely freezing and I wonder if that is the problem. It has a sloped roof which I think has zero insulation but also no access so past pulling the roof down I'm not sure what can be done there. The walls are I believe cavity but I don't think there is any insulation. To compound the problem there's double doors from the kitchen to the lounge / diner which do nothing in terms of stopping heat escaping.
There's a couple of things I think could be an issue. The doors & windows despite being uPVC double glazing aren't the greatest and I think a fair bit of heat is escaping there. I've been round with a candle and there's no obvious draft but I suspect replacement is needed. The second issue is not so easily solved. The walls are 225mm thick solid brick and therefore cavity insulation isn't an option and looking at the price of external installation its horrifically expensive. Looking around my street I can only find one house that has had it done.
So I could potentially replace the doors & windows, add cavity insulation to the kitchen and look at doing something with the double doors to stop heat escaping, although I'm not sure what to do with them. But I guess my biggest question is how can I work out if that will work. What I want to avoid is spending another big chunk of money to find out its made no difference.
Sorry for the ramble and I'm not sure there's an obvious answer but there's a lot of experience on here so hoping to pick up some pointers. Am I looking at the right things or am I wasting more money for a problem that can't be fixed easily due to the age and design of the house?
